A Late Good Evening!
As per the title - If I was to buy a TD04 turbo kit will I need anything else?
Or can I simple bolt it on and reset the JAM ECU?
For example do I also need an upgraded intake manifold?
Car:
Glanza V 1998
Mods:
Air filter relocation kit
FMIC
Toyosports Manifold & Decat
5Zigen Exhaust
JAM ECU
Your filter relocation will need modification as will your hot pipe to the cooler, a decent clutch if ya haven't got one already, oil+ water lines for the turbo, wastegate/actuator if not included in kit. And yo will obviously have to get the fueling checked
Sorry it has an uprated clutch!
The kits come with the oil & water lines, and wastegate.
My Glanza came with a Blitz 4 Stage Boost controller - can I use the actuator that is attached to my CT9 Turbo on the TD04?
I would personally stear clear of the toyosports kit buddy, its cheap and nasty! Far better just saving a little more and go for zisco, race tech or wepr. People are always selling used setups for good prices and you wont need to strip it all down again when it cracks.
Allan
If it's a Hks actuator you have you could make a new bracket for it easily
All I can say is it's a threaded / adjustable actuator?! Probably a HKS as they are so common right.
Was on the car when I bought it :-s
