Hi everyone,
I was driving down the motorway and i heard a bang from the engine bay and i then i heard the manifold blowing a lot,
After i heard that i needed to replace my turbo anyway, so I put the new turbo on and made sure i secured the manifold and turbo tight with new gaskets and it is still blowing, not as bad, but still is,
any ideas?
Thnaks
did you smooth the manifold and block first with sand paper or something similar to give the gasket a flat surface, can make a difference? Also look for cracks on the manifold
no didnt smooth it and will have a look for cracks on the manifold when i take it off, are cracks noticeable as when i had it off i didnt notice anything when changing my turbo
Edited by scottieboi94
Cracks are noticeable, just wondering what gasket your using. because everyones saying you should use an oem toyota one.
Yup brought the one you posted first used it, manifold was blowing. Changed it for the the one i posted. It's basically OEM quality they claim so should be very similar to ID Work oe ones. Up to you which one you choose. But i wouldn't go for the crush type gaskets again
Crush ones are horrendous! Used one before on my K20 civic.. had to take it all off again.. on a K20 the manifold is on the back of the engine with BARELY room for a ratchet.. i could've of killed Japspeed!
Used an Id-workz.co.uk last night. Top quality, no blowing!
