need some help with wireing want to fit my engine into a jimny 4x4
I've got a forged which I cant sell, and I have a jimny off road truck, and need some good power for tails so I am thinking of running my forged engine in it and my jam ecu, what is the main wireing I need is there a couple leads to wire up or dose the whole dash loom have to go in to?
I've done alot of engine changes , like nova redtops, corsa c20lets, redtop astra vans, escort mk2 with a cosworth engine, rs turbo mk4 vans
So I no abit about wireing lol and makeing things fit,
Any idears please let me no.
I no it would make a load of people laugh.
Edited by boosting24/7
Wirings easy, fuel cut relay is boles to the dash around the Clive bod area and the efi relay is in the fues box
Google 4efte wiring looms. Quite a few of them floating about
Edited by turbo Grant
Thanks mate il have a look on google see what I can see
http://www.toyotagtturbo.com/forums/showthread.php?20491-EP82-EP91-ECU-Pinout-Diagram
Looking at the link, on the ep82 loom.... on connector 2. Would I only have to wire in. Lead 1,2 9 into the jimny switch Live, and then 10 if I wanted a warning light?
Cheers
You need to wire it up via a couple of relays and fueses. Bits not hard at all. On the ignition switch IG2 is 12v with the ignition on, and ST1 is 12v on cranking
This is what I used. Cut all the wiring out of a GT loom
21A2120A-EC3D-4E81-B8E3-E1B85A5DB47D_zps
