Dusty Posted January 2, 2014 Posted January 2, 2014 So the last few days car hasn't been starting sum times recently but other times it will start no problem but tonight I tried to start it and the battery ran low half turning over then every time it halted turned it made a clicking/clunking noise , not to sure if this could be a sign of starter motor or sum thing else unsure May just be because the battery's low didn't want to keep trying as the battery was nearly dead anyone any ideas what it could be?Any help appreciated cheersDusty Quote
Sefton-EP91 Posted January 2, 2014 Posted January 2, 2014 Flat battery mate. Not enough power to turn the starter. The cold weather tends to kills batterys. Quote
Dusty Posted January 2, 2014 Author Posted January 2, 2014 Ok cheers guys could that be what's causing it not to start sum times?Ordering a shed load of stuff for TD end of the monthwas told it was the fuel pump that was gone when it wasn't starting sumtimes, but I guess I've killed the battery tryin to turn it over to much because tonight I tried to start it and it half started as if it was going to start then just kept turning over with this new clunking noiseCheers guys Quote
