Glanzar Posted January 6, 2014 Posted January 6, 2014 Hi , im bet im not wrong in sayin this question has been asked many times but ill ask anyways...I just brought my glanza v pretty standard apart from fpr - fcd - elec boost controll ..Im lookin to buy a full turbo setup but undecided weather to go for the td04 or a k24 could someone shed some light on which is best?Also which kits do you recommend? Im looking to forge it soon if that changes anything? Quote
TurboTobz Posted January 6, 2014 Posted January 6, 2014 (edited) Very similar turbos will get slightly more power from the td04 and slightly better spool from the k24 not a lot in it though.Ive had a k24 its just a bitch as theyre very rare so replacing it is tough and expensive td04s are 40 ish and easily available you.K24 can be upgraded to k26 for more power if your forgingTd04 can be upgraded to td05 and the vf series turbos and also the tf035 which is smaller than td04The above can be Swapped over without changing manifold or decat Edited January 6, 2014 by TurboTobz Quote
Glanzar Posted January 6, 2014 Author Posted January 6, 2014 Thanks for the reply , i was looking at td05's but wasnt sure on them as fewer people ran them? Quote
TurboTobz Posted January 6, 2014 Posted January 6, 2014 Td05 is inefficient at only 1bar as theyre barely working to produce it so people running them are usually forged.I had one running a bar and it was very fun, people running forged lumps usually lean toward the vf turbos as they have high power output and great spool times. Quote
Glanzar Posted January 6, 2014 Author Posted January 6, 2014 Ah i got it now td04 looks like the turbo for now , do you recommend a specific brand i.e racetech i heard were good Quote
TurboTobz Posted January 6, 2014 Posted January 6, 2014 No, would look into the main ones apwak to mike at tuning devs, wepr wicked ep racing, zisco, dean at rw developments, and of course race tech.I have owned wepr sard and zisco the sard was the k24 kit Quote
