Differences between Upgraded Injectors and fuel p regulator?
To make the most of it you would need a programmable management system to adjust the opening times of the injectors, but if you do decide to fit larger injectors you can reduce the fuel pressure.
Depends what boost your running really, 1 bar on a td04 and the stock injectors are fine.
