Hi all,
I recently did a headgasket and cambelt change on my daily and changed the coolant. Now, it takes a while to get up to temp and when it does, it stays just above a quarter. I bled the system and it can through the bleed points aswel. Got tonnes if good heat through the heaters..
In the winter that's pretty normal. When u start boosting it will go up to half way.
Keep an eye in your coolant for a while just in case, but sounds good to me
Edited by 5T4R7ET N/A
I flushed and replaced the cooling system and ran it up and didn't loose no coolant. Just very odd as it took ages. My missus took it out for a drive and it went up to around half ( normal ).
