Sounds like its coming from the driveshafts, only does it occasionally above 2,000rpm and when turning the wheel slightly. Sort of come from nowhere yesterday. Im leaning towards cv joint?
Edited by Ollieh17
Noise disappeared for a day and now has got worse. Seems about 2,000rpm the knock,knock,knock starts then goes away with a bit more speed. Noise is alot louder when steering with revs. Also sometimes the steering wheel pulls against me? Kinda worried about this
hmmm interesting jack it up and have a look also check the wheel bearing while your there see if its gone i had mine go a while back and it was pretty much as your describing
