conorIRLgt Posted January 12, 2014 Posted January 12, 2014 Well lads just wodering has manypeople used 75mm pistons in a 4e , is there enough meat in the cylinder wall to do it ?will be using ross pistons if its any help.. Quote
yaristurbo Posted January 12, 2014 Posted January 12, 2014 (edited) I'm boring to 75mm on 5e, been looking around for blocks cracking and found nothing so far, heard a lot of people using 75mm vitara pistons so should be okBest this is to get the block ultrasounded there a tool that measures the block walls properly Other thing is most places stock 75mm pistons too so can't be proneThere is not much cc gain tho, mainly done if a 74.5 has scored the boreIs there a reason for the rebore? Edited January 12, 2014 by yaristurbo Quote
conorIRLgt Posted January 12, 2014 Author Posted January 12, 2014 mainly going for the few extra cc's every little will help with the 4e hopefully Quote
yaristurbo Posted January 12, 2014 Posted January 12, 2014 Think it was something like 1497cc to 1530cc can't remember now Quote
aidanep71 Posted January 12, 2014 Posted January 12, 2014 That's a nice gain from the 1330 or whatever they are from std Quote
conorIRLgt Posted January 12, 2014 Author Posted January 12, 2014 Yeh man shorty went to 75.5 mm on a 4e ? if so i might look into that Quote
AdamB Posted January 13, 2014 Posted January 13, 2014 Yeah shorty was on a 4E.I don't see the need to go 75mm personally, the slightly increased engine capacity and compression ratio isn't worth it. You have to factor in that if anything goes wrong your screwed as you can't buy next size up off the shelf. Exactly the reason why YT is having to go upto 75mm because the bore was ruined. Quote
