Got set meisters fitted them yesterday but the front passenger side seem to have a knocking sound going on when I come to a bumpy road got all dampers set up the same and spring set the same don't think it's a problem with the wheel/tyre no running at all on full lock both ways no problem turning any ideas why a this could be ?
Only happens when it gets a little bumpy on perfect flat roads no knocking/cluncking at all and suggesting will be good
Thanks 👍
Did you fit them yourself? Did double check all bolts are right?
Also check the nut on the top mount as they can work their way loose sometimes. It's the silver one in the middle of the top mount (17 or 19mm socket from memory).
