Dicky-Art Posted January 21, 2014 Share Posted January 21, 2014 How much am I looking at for a garage to replace a supplied gearbox?How long do you think it would take? Quote Link to post Share on other sites
yaristurbo Posted January 21, 2014 Share Posted January 21, 2014 Couple of hours all goes on book time though Quote Link to post Share on other sites
Dicky-Art Posted January 22, 2014 Author Share Posted January 22, 2014 £100 ? Quote Link to post Share on other sites
Zeldoz Posted January 22, 2014 Share Posted January 22, 2014 Book time = 3.1 hours. Two of us did it in 2:45 on a driveway! Quote Link to post Share on other sites
Mikeyallgood85 Posted January 22, 2014 Share Posted January 22, 2014 I paid £120 for my clutch and flywheel replacement obviously the gearbox came out! I'd say £100 to change yours! Quote Link to post Share on other sites
Dicky-Art Posted January 26, 2014 Author Share Posted January 26, 2014 Well I've started doing it myself on the drive.Spend all day clearing air box/battery/clutch cylinder and linkages out the way and removing the drive shaft. Couldn't split the bottom ball joint and couldn't remove the three bolts on the control arm. In the end I unbolted the strut and steering joint and the shaft levered out the gearbox easily with a tyre lever. Took the hub nut off to removed the shaft totally.Stopped when it started hailing.Got a new clutch for it too.Gearbox should be here Tuesday. Quote Link to post Share on other sites
hookie663 Posted January 26, 2014 Share Posted January 26, 2014 Yea be wise change clutch wen your that far if it wasn't replaced resently Quote Link to post Share on other sites
Dicky-Art Posted January 27, 2014 Author Share Posted January 27, 2014 On 1/26/2014 at 7:34 PM, hookie663 said: Yea be wise change clutch wen your that far if it wasn't replaced resently My thoughts too....£50 for 3 piece kit from http://www.carparts4less.co.uk/?gclid=CO2HxJaAnrwCFUT3wgodGjIA-g googled a discount code and got 7.5% off! Quote Link to post Share on other sites
Dicky-Art Posted February 9, 2014 Author Share Posted February 9, 2014 Well can't get the bugger fitted! 3 full days trying and stripping more bits off to give more manoeuvrability! Just borrowed a hoist but still no joy! :sad: :sad: Quote Link to post Share on other sites
Dicky-Art Posted February 15, 2014 Author Share Posted February 15, 2014 Finally got it bolted up Quote Link to post Share on other sites
Dicky-Art Posted February 22, 2014 Author Share Posted February 22, 2014 Runs perfect! Cheers Dangee Quote Link to post Share on other sites
