took the spring out of my oil pressure relief valve from my '92 GT engine. Then took the spring out of the one from the ep91 uk spec starlet engine I have spare, the spring feels ever so slightly stiffer, looks newer too....
Should I use the newer starlet ep91 spring or stick to using mine?!
Cheers :)
there isnt a huge difference, the springs are both the same, but one is ever so slightly stiffer than the other , BARELY, but not sure if itd make much difference?
