Tobyb94 Posted January 22, 2014 Posted January 22, 2014 My plug keep sooting up so much I get a misfire new plugs have lasted less than 3 weeks what the best plugs to use or would a higher heat grade help Quote
Tobyb94 Posted January 23, 2014 Author Posted January 23, 2014 needs another map but can not afford one right now Quote
Chris_GlanzaV98 Posted January 23, 2014 Posted January 23, 2014 As above you will be overfuelling and by the sounds of it quite a bit, try not to drive the car as much if possible and get it mapped asap ! Quote
