Hi all, my car failed the nct because the abs light is on.
Its throwing up faults 31,32,33,34 which are the four wheel speed sensor circuits.
I cannot take out the abs, remove the bulb or wire it up to another light as the centre know the car has abs and expect the light to come on, do a faults test and go off a few seconds later.
Has anyone else ever had experienc of any of these wheel speed sensor circuits?
Any advice on how to get it fixed?
did ya clean the sensors vincent..?? are the ABS rings there..??
also, remove one of the sensors (still plugged into loom) and turn on ignition and see if the tip of the sensor is magnetized.. (try stick a screw, bolt or screw driver to it)
