That particular power goes to a block of fuses inside the fuse box in the engine bay. They are red and green if I remember correctly.
If not it does look suspiciously like the alternator positive wire with the other plug next to it.
The positive will be next to the diagnostic port or at least close to it!
The loom is split into two seperate sections, of which is the large section which goes behind the clocks and dash, then you get another section which comes through the firewall and has all the injector harness and the rest of the engine bay plugs on.
