dangeestarlet Posted January 27, 2014 Share Posted January 27, 2014 As above can't seem to find possitive battery lead on my loom Quote Link to post Share on other sites
AdamB Posted January 27, 2014 Share Posted January 27, 2014 Yeah that's the positive. I'm sure the earth is strapped to the inner wing, well it was on mine. Quote Link to post Share on other sites
Flaminsam Posted January 28, 2014 Share Posted January 28, 2014 That particular power goes to a block of fuses inside the fuse box in the engine bay. They are red and green if I remember correctly. If not it does look suspiciously like the alternator positive wire with the other plug next to it. Quote Link to post Share on other sites
ryan lang Posted January 28, 2014 Share Posted January 28, 2014 Yeah that's for the alternator Quote Link to post Share on other sites
Taggy Posted January 28, 2014 Share Posted January 28, 2014 The positive will be next to the diagnostic port or at least close to it! The loom is split into two seperate sections, of which is the large section which goes behind the clocks and dash, then you get another section which comes through the firewall and has all the injector harness and the rest of the engine bay plugs on. Quote Link to post Share on other sites
dangeestarlet Posted January 28, 2014 Author Share Posted January 28, 2014 Thanks for all your help guys , much appreciated Quote Link to post Share on other sites
