Murphy177 Posted January 28, 2014 Posted January 28, 2014 So I'm running ct9 ATM if I change to td05 or td04 will it bolt straight on? Or will I have to change intercooler pipes? Will anyone help with pictures... And if I swapped can I drive it with it like that until I could get it mapped or not ? Quote
Liam_D Posted January 28, 2014 Posted January 28, 2014 You'll need a TD/VF Series manifold and downpipe mate that's the most important part, as well as some new oil/water turbo lines and a new hot side intercooler pipe but the Ct9 one can be modified to suit. You can drive it unmapped aslong as you don't try to run massive boost and don't kick it's head in too much. Quote
Murphy177 Posted January 28, 2014 Author Posted January 28, 2014 Ok cheers got all that except the intercooler pipe how do I adapt it? Cheers mate Quote
