I want to up the boost on my standard turbo.
I have hks Fcd, hks actuator, FPR
What would I have to set the Fcd and fpr to If I set the actuator to 1 bar?
Thanks
Trial and error really as every car is different, around 7 or 8 is the most common though. You want the lowest setting without it hitting fuel cut.
Fuel pressure setup you'll need an air/fuel ratio gauge to judge, and a set of det cans/knockbox to monitor knock levels.
