ok so my car would splutter and is hesitant under 2000rpm when crusing. When i go over this its perfect. It started suddently like 5 months ago. I heard it might be overfuelling. I got a BLITZ ecu, decat, front mount, stanrd air filter, turbo and boost. What is causing this. i can smell petrol and the plugs have dark carbon on dem. The car aint as economic as before. It goes well but just plutters under 2000rpm like its having trouble moving but after 2000rpm its perfect. How can i fix this? anyone got solutions?????
but I had all these mods before and it was fine so something has gone wrong?? anyone have ideas what it could be?????
does anyone know a mechanic around London who knows these cars well???? thanks guys
i changed the sparks. they are iridiums heat 6 and leads are blue magnecores. could it be dizzy cap? and it the heat range ok or should it be higher? boost and turbo is standard??
it started doing this the same time i serviced it. could the oil filter be damaged and wont let the oil through easily under load???? i checked all injectors and ht leads etc there al good. so that the only thing im thinking that nder 2000rpm the oil is having trouble going through the filter so the car is spluttering and hesitant..
Ive been having issues with stalling possibly to over fuelling. Had the IAC valve on my intake cleaned but looks like it needs replacing...
