Injectors do click as part of normal operation so I wouldn't be too worried about it. What ecu are you running?
Hmm interesting
If you can be bothered, you could test the injectors without the engine running and make sure they're all working? Unplug the coil and the fuel pump and then either plug in a spare dizzy and spin it by hand or pop your one out and spin it. The engine doesn't turn but as the trigger is telling the ecu it is so the injectors will operate. See if its making the sound your hearing.
