Evo_stevo Posted February 19, 2014 Posted February 19, 2014 The drivers door lock in my ep91 Glanza is a bit tired and some times requires abit fiddling to get it to open.The passenger door is very smooth and operates no problem and feels very tight.I'm going to remove the horseshoe clip that holds the lock in and tighten it a bit but I wondered if I can swap the lock from the passengers door onto the drivers door??Does anyone know if this can be done before I try it?? Quote
Azz Posted February 19, 2014 Posted February 19, 2014 Shouldn't think it would be a problem to be honest just swap them round.Bit of advice though I took mine out and left them in oil/petrol over nights and it worked fantastic afterwards, Quote
Evo_stevo Posted February 21, 2014 Author Posted February 21, 2014 Cheers for reply mate, I'll give it a go see if it fits.The locks not seized or hard to operate, if anything it's worn and become fiddly to use. The passenger side is good on the other hand with not getting used so a swap would be ideal. Quote
Azz Posted February 21, 2014 Posted February 21, 2014 If needs be you can always get a set of locks from a breakers, both doors and ignition barrel plus keys Quote
