I'm assuming that's the sensor between the alt and the starter single plug felly? If so what end does the wire come from as mines isn't plugged in and the eml light comes on after a rev I can't see a wire for the knock sensor does it come of the alt wiring?
Jointed it back up and fitted a spade connector on it but eml still Coming on u think if I reset the ecu it might work I've disconnected the batt anyways so see what happens
