People running this clutch are your biting points near the top? As in only have to dip the pedal slightly to engage a gear.
Also anyone running 300ft/lb on it?
Yeah its very juddery if you try to pull of normally almost need to burn the clutch
It will hold over 300lbs no sweat mate so dont worry about that !
At my garage yesterday they had a mk5 golf in with the box of and it had a spec clutch and flywheel combo same as mine as it was over 400ft lbs
