natalie_fuller Posted February 20, 2014 Posted February 20, 2014 Hi all. I am going for the G6 Gearbox, I have everything out and now I am stuck. I have the shifter and cables from the E11 the gearbox came out of. right now what do I need to use? The GT shifter with the G6 cables, they don't fit on to the shifter and the E11 shifter is to gig to fit on the mounting brackets. I am due an op next week so I am wanting to get as much done as I can before then. Thanks Rob Quote
morgey Posted February 20, 2014 Posted February 20, 2014 Have you tried just using the gt shifter and cables? Quote
natalie_fuller Posted February 21, 2014 Author Posted February 21, 2014 No I have not yet, I was told there would not to be able to select some gears. But I think I might as well give it a shot. Quote
motion Posted February 21, 2014 Posted February 21, 2014 I got the g6 gearbox with the ep91 cables and shifter. ....i had some troubles with the 3. Gear but then i "modified" the cable holder on the gearbox and now it works well.....you need a hammer and some washers. ..i will take a picture Quote
natalie_fuller Posted February 21, 2014 Author Posted February 21, 2014 Motion. Thank you your a legend. : ) Quote
motion Posted February 21, 2014 Posted February 21, 2014 You need to habituate a few days but then it works fine....the gears are really near. ..no need for a shortshifter Quote
natalie_fuller Posted February 21, 2014 Author Posted February 21, 2014 Epic thanks matey. Just one more question lol did you use the e11 cable mount on the gearbox or the 4efte one Quote
motion Posted February 21, 2014 Posted February 21, 2014 (edited) E11 cable mountbut remember I have a 4e-fe! there could be differences because of different oem gearboxes....just try it. Edited February 21, 2014 by motion Quote
natalie_fuller Posted February 21, 2014 Author Posted February 21, 2014 Cool man I will let you know how i get on Quote
motion Posted February 21, 2014 Posted February 21, 2014 Cool man I will let you know how i get on Quote
