'is the exedy (standard replacement) ep91 non turbo and the ep91 turbo clutch housing the same part? I just want the housing and bearing as going to put a fast road helix plate in(will I need the fast road housing aswell or will it be ok?). or should I just go for the exedy stage 1 organic? whats best value fast road clutch going? any help much appreciated :hi:
The clutch friction plates and pressure plates are different. The 4E-FE is 12mm smaller.
The Exedy Organics are good but I recommend the Competition 6 PUK. Great bit of kit and fairly comfortable to drive with. We have these on our website along with the Exedy range.
cheers for the info idrees :hi:how much is decent standard -fte clutch cover and bearing or would I have to buy full kit? seen a fast road organic helix plate on its own I want.
I have currently got an exedy organic good clutch but not sure if it will take the 250 ish hp I'll be making once I forge my engine. Depends what your goal is organic will be fine for 200 - 220 but if planning on more save money in the long run and get a competition clutch 6 puc like idrees has said rather than doing what I did and buy an organic and prob ending up buying something else again
yeah im hoping to be happy around the 220bhp mark, tdo4 on a bar should be entertaining enough :thumbsup: Exedy stage 1 it is ....just got to find the cheapest supplier now thanks aidan
