Farrell Posted February 24, 2014 Share Posted February 24, 2014 Im hoping theres a simple solution to this but the Central/ Spoiler Brake light on my glanza isnt working, Thought it could just be a bulb but quickly realised that its LED, the other two brake lights work fine so im not sure its the fuse as i would think that all three are fused together? i only had a quick look but if anybody has any suggestions it would be greatly appreciated! Quote Link to post Share on other sites
EP91crazy Posted February 25, 2014 Share Posted February 25, 2014 If you whip the led cluster out thete should be a plug on the end this leads to the right hand side of the boot lid. There's a small grommet you pop out and the leads are in there. Get a piece of welding rod and tape . Tape the end you need to the rod pull it out plug it up and walla . That's how mine was on my ep91 easier said then done tho Quote Link to post Share on other sites
Farrell Posted February 25, 2014 Author Share Posted February 25, 2014 If you whip the led cluster out thete should be a plug on the end this leads to the right hand side of the boot lid. There's a small grommet you pop out and the leads are in there. Get a piece of welding rod and tape . Tape the end you need to the rod pull it out plug it up and walla . That's how mine was on my ep91 easier said then done tho oh so its not even connected? Quote Link to post Share on other sites
EP91crazy Posted February 25, 2014 Share Posted February 25, 2014 Possibly not. Mine wasn't. I wiped my cluster out. Managed to pull plug through and connect them up and it worked Quote Link to post Share on other sites
Farrell Posted February 25, 2014 Author Share Posted February 25, 2014 Possibly not. Mine wasn't. I wiped my cluster out. Managed to pull plug through and connect them up and it worked how very strange, okay thanks mate, il give that a go Quote Link to post Share on other sites
