Turbo Goose Posted March 1, 2014 Posted March 1, 2014 Hi guys picked up a glanza today. Seems to run sweet as a nut up until high boost.Its got a fcd and fpr setup.Runs approx 0.9 bar, little less in lower gears.I can sort of avoid it by using 3/4 throttle but if I boot it, it kicks out black smoke and feels bit like 3 cylinders. It will missfire a bit under full throttle then get really bad past bout 6kThe fpr is at 3 bar, the fcd has a sticker on the adjuster that says close? So cant see what its set toAny ideas?Thanks Quote
enots Posted March 2, 2014 Posted March 2, 2014 have you tried turning the boost down to stock boost?also might be worth checking plugs leads etc if its missfiring Quote
Turbo Goose Posted March 3, 2014 Author Posted March 3, 2014 Ive ordered new plugs as its got pretty spankin ngk silicone leads. If that doesnt solve it ill turn boost down and take to rr I think. It pulls like a train at 3/4 throttle Quote
Turk Posted March 6, 2014 Posted March 6, 2014 My friend had the exact same problem on his skyline. Get a timing light on there. Seems like your ignition timing is off. Someone might have played about with the dizzy Quote
