I have a braided oil feed I want to fit, had a look today and it looks pretty tight to get to. What's the best way to go about installing this?
Advice would be appreciated
Cheers
To fit mine: i jacked it up and fitted from underneath, attach to the turbo and bolt up loosely then attach the other end to oil feed on the block. Tighten them all up
Its very awkward to get to if you've still got aircon pump fitted. Otherwise still a bit awkward to get the angle for the thread and banjo bolt but not hard
