hi
my car was running fine just changed the turbo to a gt28r all running sweet as a nut (didn't drive it but lefted ticking over for about 15mins a couple of times)
so I go ahead and change the water pump and alternator so when I was done go to start it starts up but it was cutting out time a timer everyone 1sec turned it off had a look checking all air/oil/fuel piles all looked fine tried again started but then cut out straight away?
I think I might of knocked a wire off when doing the waterpump and alternator what sensors and wire's are by there?
I checked wires are connected check all earths, fuel ,spark , compression, fuel pump everythink seem's to be working the plugs and getting fuel everything is working but it just don't wanna go. I have not played with the timing?
I have looked on the web not there is not a lot of help about this? im really confused and a need of help
I looked at that all seems fine ;( the car started the but was playing up a little it was like 1 sec misss fire on and off like revving a car every sec
