Item For Sale:IHI VF24 Ball Bearing Turbo and Toyosports manifold and decat downpipe
Item Condition & Description:Turbo is in excellent condition and has been gasket matched and ported/polished to improve flow and spool
Fantastic alternative to a TD04 And will make 330Bhp + On a built engine, or at a bar around 250Hp on a stock motor.
Spool started same time if not slightly earlier than a TD04, Yet full boost didnt come in till around 300rpm later due the to Ball Bearing Design
Manifold is braced and has been fine for the time i have used it, yet needs some welding as it is cracked round the collector (See in photos) Decat is in perfect working order. There is also a custom actuator kit which is set at a bar, which bolts to the standard block of a 4E/5E Engine to use with an internal gate :)
Will bolt straight on as a complete kit with only a small amount of welding work required!
Price: £250
Payment & Shipping Details:Shipping i can sort but would be grateful if you could sort collection out and i will pay it / Knock a bit off the price
Literally on the verge of buying one of these turbos and the manifold and decat, but I'm not keen on stainless manifolds :( and I will miss my ZISCO mild steel ct9 one strangely! Temptation is a bitch.
  • 3 months later...
