Taggy Posted March 12, 2014 Posted March 12, 2014 (edited) having a right old time trying to fix a code 52 fault, which is supposed to be knock sensor failure or open circuit. Has anyone had this fault code and what did their car run like? The car runs ok, but it seems to be massively over fueling, put your foot down ans it fuels straight to 10 on the AFR and goes off the scale.The car is also mis firing and underpowered on full chat. Is this normal when it pull a error code 52 on the eml? i am figuring the ecu is fucking up my map! Doing my head in as i have change knock sensor and its still doing it, argh Edited March 12, 2014 by Taggy Quote
Jap91 Posted March 13, 2014 Posted March 13, 2014 Having the same prob check the wire is well insulated and not broken Quote
Starbuck Posted March 13, 2014 Posted March 13, 2014 Is the knock a standard oem Toyota knock sensor? Quote
Taggy Posted March 13, 2014 Author Posted March 13, 2014 I have run in a new section of cable (insulated) and also tested another knock sensor and i still get the error. Once the car gets to about 3-4000rpm the eml light comes on irespective if the knock sensor is plugged in or not. Gonna get the multimeter out again tonight and test the continuity again to the plug, failing that all i have left to change is the ECU. Is the knock a standard oem Toyota knock sensor? Quote
rinseep82 Posted March 13, 2014 Posted March 13, 2014 I'm not 100% mate but check all fuses under the engine bay I had this problem with knock sensor / open circuit changed the sensor and still had it checked all fuses and one had gone changed it and all was good worth a try Quote
philfrost432 Posted April 2, 2014 Posted April 2, 2014 Did you buy a new sensor or used as could of been sold a duff one mate there are many arsholes out there that will do it, my knock sensor went error 52 replaced sensor and was fine mate Quote
