Baz-GlanzaV Posted March 18, 2014 Posted March 18, 2014 Anyone know of any garages/mechanics in South Yorkshire area that would be able fit my turbo timer as in instructions it says needs connecting to ignition, handbrake sensor & ecu? Any help is much appreciated thanks. Quote
Baz-GlanzaV Posted March 18, 2014 Author Posted March 18, 2014 Knew you'd pop up! 😒 all local garages I've asked won't do it 😠 run out of ideas so thought see if anyone can recommend anywhere. Quote
seab Posted March 21, 2014 Posted March 21, 2014 DIY the ecu handbrake bits are optional. Just so it can shut the car down if the handbrake is dropped and the auto function can monitor and set the time according to running conditions Quote
Dean_mc88 Posted March 21, 2014 Posted March 21, 2014 As above its optional however its a nice safety feature to have, depending on what turbo timer you have you can by a harness that makes it a piece of piss, its basically plug and play and the handbrake bit is nearly as simple just use a compression connector to tap into the handbrake cable wire cant remember what wire it is but there are only two. Quote
seab Posted March 21, 2014 Posted March 21, 2014 What turbo timer is it? Im only in Huddersfield if you need a hand. Quote
Baz-GlanzaV Posted March 23, 2014 Author Posted March 23, 2014 I'm not clued up regarding electrics/wires but mate who is works away so been tricky finding someone (garage) who can do it. It's an apexi turbo timer. I'll check if it came with harness and let you know. Seab I'll be local to you soon when pick some bits up from iddy I'll give you a shout mate. Thanks. Quote
