Was just wondering is it possible to still have rear seats which passengers can use with having harnesses at the front? If so is there a tutorial on how to do it? :)
use the fixings from the original seat belts there's a fixing inside where the belt is able to slide forward and back on a bar get a new bolt that has an eye and replace this.
For the harness that go over the seat you can either attach that to the seat bolts at the back but will need two more eye hole bolts this will keep the harnesse's tidy and close to the seat
This one you can see the way its done on the drivers side
And these are the bolts I'm talking about I don't know there exact name
they can be got from ebay usually when you order your harnesses they ask which car there for and supply these you just need to find out the thread size of the two rear seat bolts and the one inside the door for the seat belt near the floor in the first picture.
You can leave your existing seat belts in place along with seat belt clip on side on seat for an mot and just unclip the harnesses from the eye hooks
As above, i always used to keep the seat belt but use the eye bolt to secure my seatbelt, Never had any issue.
