Hi ive been strugling with a misfire and some hesatation for some time now, running a td04 under fuel cut at stock fuel pressure.. So far ive changed the plugs, fitted trd leads, a brand new oem king lead, new dizzy cap and a new rotor arm. However im still experiencing the problem. Its very random and intermittent and seems to go when at very small amounts of throttle or wide open throttle :/
Im struggling for ideas now and would really appreciate some help
hey sandham check your plug gap first if there grand check for water consumption ( fucked headgasked )
seeing u changed the rest for new that eliminates that
i had this to before long ago and changed evry thing and it was still there in the end i was leaking water in mi cylinders !!!
Ive reduced the gap to 0.9 and its helped abit but still just some slight hesitation occasionaly. I did notice one of my spark plugs had a tiny amount of oil on the top half so maybe its that? It never crossed my mind to be honest
Also id be after both parts mate because i dont know which is at fault
Edited by Sandham
