Jim* Posted March 19, 2014 Posted March 19, 2014 (edited) got this greddy profec 2 but no sure where everything goes? anybody shed some light on this? There is also a vac port on the back of the unit Edited March 19, 2014 by Jim* Quote
Mk3 silver gt Posted March 19, 2014 Posted March 19, 2014 I've just wired mine in today and I used the power wire from the cig lighter and earthed it under the dash for the red n black wires.That port at the back or the unit is for pressure reading so you would need some 4mm silicone hose and run thru the bulk head to the engine bay and t-piece it to vacum source behind inlet manifold.On the boost solenoid its currently set up for external w/g but if your still running actuator the nipple needs moving it should be COM to actuator, NO to turbo nippleHope this helps and if you get stuck let me know I've got the manual here Quote
Jim* Posted March 19, 2014 Author Posted March 19, 2014 I'll be running external wastegate setup but this dosen't have a line coming from NO Quote
Mk3 silver gt Posted March 19, 2014 Posted March 19, 2014 Alrite leave pipes where they are, bt the NO port needs to be left open for when it bleeds the pressure Quote
Jim* Posted March 19, 2014 Author Posted March 19, 2014 oh so i don't put anything into that then? but i do need a vac going into the back of the unit from the inlet? the two coming off the solenoid go onto the external wastegate? which part goes onto the turbo nipple? Quote
Jim* Posted March 19, 2014 Author Posted March 19, 2014 missed out this bottom pipe also, and the t piece on the blue pipes what is that for? Quote
Mk3 silver gt Posted March 19, 2014 Posted March 19, 2014 Yeah leave NO open, that pipe with the little filter if its long enough use that for nipple on the back of the controller.COM port goes to wastegate and NC port goes to turbo nipple Quote
Mk3 silver gt Posted March 19, 2014 Posted March 19, 2014 This mite make it easier http://i819.photobucket.com/albums/zz113/djl077/Capture-6.png Quote
Jim* Posted March 19, 2014 Author Posted March 19, 2014 the one coming out of the NC port had a t piece coming from it, whats this for? Quote
Jim* Posted March 19, 2014 Author Posted March 19, 2014 ahh makes sense mate thanks for your help buddy! Quote
