What goes where?
3B761FF5-E642-4871-A41F-62B56CA1A91C_zps
got this greddy profec 2 but no sure where everything goes?
anybody shed some light on this?
There is also a vac port on the back of the unit
Edited by Jim*
I've just wired mine in today and I used the power wire from the cig lighter and earthed it under the dash for the red n black wires.
That port at the back or the unit is for pressure reading so you would need some 4mm silicone hose and run thru the bulk head to the engine bay and t-piece it to vacum source behind inlet manifold.
On the boost solenoid its currently set up for external w/g but if your still running actuator the nipple needs moving it should be COM to actuator, NO to turbo nipple
Hope this helps and if you get stuck let me know I've got the manual here :)
oh so i don't put anything into that then? but i do need a vac going into the back of the unit from the inlet?
the two coming off the solenoid go onto the external wastegate?
which part goes onto the turbo nipple?
