Awaiting delivery of my Apexi power fc while my cars off the road and will be fitting it and yet again tidying my loom out to make sure everything is A1.
My question is regarding the map sensor, i know the starlet ones only do 1.2 Bar so need uprating to read more.
However as i have an AVCR im wondering if the Power FC will use this for boost display/monitoring and also for adjusting fuelling?
Obviously my AVCR is spliced into the factory loom at the moment. im aware the AVCR reads of its own map sensor as displays whatever upto 2 bar (i know due to boost spike of over 2bar on the old engine lol)
Main questions are do i need an uprated map sensor in the standard place in the loom for the ecu to adjust fuelling or will it use the AVCR signal from where jts currently spliced?
Sounds confusing and i have confused myself a bit lol. Has anybody had expierence with these before?
Thanks!
I don't believe u can make either of the devices talk/work together...
A good map sensor to buy is a Celica GT4 map sensor. Will allow you to go up to 1.7bar... Plug n Play too!
Failing that go for the 3bar map sensor apexi make...
Quick google session shows people have used the avcr sensor as its the same thing, only part im confused on is the sensor it will pick up fuelling from which i think is the standard one.
And thanks socks :)
