I made a integra dc2 rails fit my ep with a bit of work and I think there the same as ek9 ones. The front two feet need a bit of bending and the holes making bigger which is pretty easy. The rear one nearest the door needs to be bent a bit flatter and then cut off and welded as the rails are slightly longer than ep ones. Then I made a bracket from the exhaust tunnel mount on the ep which bolted to the last hole on the dc2 rails. Doesn't take long do if your good with a welder or know someone who is and it's a lot cheaper than sourcing ep rails.
