Rob Scott Posted April 2, 2014 Posted April 2, 2014 Allreet,Where can i find a decent headgasket for around 50 english pounds? Its not for a turbo motor, just high compression n/aCheers Rob Quote
Idrees Posted April 2, 2014 Posted April 2, 2014 HiWe have 0.5mm steel head gaskets in stock, available at just £60 delivered. These are perfect for a N/A build.We also have the original gasket available at £42.90 + delivery. These are also on the shelf. RegardsIdreesID-Workz Ltd Quote
Rob Scott Posted April 2, 2014 Author Posted April 2, 2014 hi mate, which would you recomend? i usually use OEM gaskets, is the steel item any good? Quote
