dbrunton Posted April 7, 2014 Posted April 7, 2014 Has anyone got any tips on changing the standard wheel with an after market wheel. Quote
Starlet-Joshy Posted April 10, 2014 Posted April 10, 2014 Firstly Disconnect the battery! Don'twant that fucker blowing up in your face! Leave it for like half hour to be safe, Then there should be two screws on the plastic, (key in ignition but not on) so you can turn the wheel left and right to get to screws without steering lock. *Im sure there is a guide about if not im changing mine on weekend, have done it before so ill take some pics* Hope that's some help Josh. Quote
seab Posted April 12, 2014 Posted April 12, 2014 I wouldn't worry about leaving half an hour. The trick I always use is to disconnect battery, switch headlights on as it will drain any residual current. Then I tend to work to the side of the wheel incase something goes amiss and it does blow it won't go in my face or injure me Quote
