ash p Posted April 10, 2014 Posted April 10, 2014 Does anyone produce camshafts like the cruise ones on here? Quote
Rob Scott Posted April 11, 2014 Posted April 11, 2014 dave newman does cams. £160, any grind you want. Quote
AdamB Posted April 11, 2014 Posted April 11, 2014 You need to get innovative with getting the valve clearences correct with regrinds, and make sure they go through some hardnening process and your valve spring base pressures are correct or you'll chew through the lobes in no time at all. Quote
