richardc9052 Posted April 15, 2014 Posted April 15, 2014 So i put my starlet all back together and bled the clutch and brakes and checked for gear oil.Now the gears are very stiff like the clutch isnt disengaging fully but i can change them but with grind? The starlet drove fine before withe the 1e in.. I put a 4efte clutch and flywheel onto the 4efe and used the 4 speed box and kept the 1e clutch release bearing. Is that the problem??The other thing i noticed is there was a 1mm small plate with holes in it behind the flywheel on the 4efte when i took it off.. I lost this. Did i need it?? Really annoying as I've just don't the whole conversion and now this..The 4 speed box on the 4e isn't the cause, they are the same but slightly shorter. I'm edging towards that small spacer? Quote
richardc9052 Posted April 15, 2014 Author Posted April 15, 2014 It has no problem going into gear with the engine off though.. going to try and find some time and pull the box, clutch and fly out and reassemble it with that spacer thing in and see what happens Quote
