Hi guys, just wondered what are good uprated shockers? As i don't fancy coil-overs.. Looking to do a few track days in the glanza so focusing on the handling at the moment because it handles like dog shit lol, i have 40mm lowering springs but other than that the suspension/chassis is standard.. Can anybody help please?
If you are looking into doing track day, why not get coilovers?
You will benefit from using a much stiffer linear rate springs with adjustable damper.
That will help control the weight transfer (body roll) and make the car much more stable on track.
Jerrick
If you really dont want coilovers. You can go for koni shocks which are damping adjustable but expensive. If you want cheaper stuff. Go for kyb gas shocks which i beleive should last longer then normal shocks on lower springs. But everything said above makes more sense
