Can anyone help when I start my car after 60 secs the temp gauge is beyond the H on it but the engine is not even heated up properly yet aye have been told this is coolant temp sensor can anyone confirm this
It's either the censor (single wire plug on the thermostat housing) or the gauge itself, best way to test is unplug the wire from the censor n see if it still happens ☺️
  • 2 weeks later...
If the wiring becomes disconnected from the coolant temp sensor then your temp gauge needle will point to H
As above the issue can only be the gauge itself on the speedo... the wiring as I explained above....or the sensor itself
Ransomed mine drops down to cold? :S
