Temperature gauge
If the wiring becomes disconnected from the coolant temp sensor then your temp gauge needle will point to H
As above the issue can only be the gauge itself on the speedo... the wiring as I explained above....or the sensor itself
Ransomed mine drops down to cold? :S
