PWG123 Posted April 22, 2014 Posted April 22, 2014 (edited) Just fitted a Speedvision Spec 2 CT9 as my CT12 decided it had taken enough boost R.I.P lol.basically I was fluttering the CT12 before with no bov ( I know I shouldn't of been, but dat flutter ;)I don't want to flutter this turbo as it's new and shiny. But my baileys won't dump unless the clutch is down or in neutral. While driving it'll flutter then dump the bov after most of the pressure has been released.I've checked vac, oiled piston in baileys, added bigger vac pipes and no luck any idea's why it's not working lads? Cheers Edited April 22, 2014 by PWG123 Quote
maddox710 Posted April 22, 2014 Posted April 22, 2014 Get rid of the baileys mate they are terrible bump valves Quote
PWG123 Posted April 22, 2014 Author Posted April 22, 2014 It was on the car when I got it, want a ssqv4 but just want it working tbhCheers Quote
maddox710 Posted April 22, 2014 Posted April 22, 2014 It won't work again I can assure you.theyre just a cheap nasty bov that like to seize all the time Quote
PWG123 Posted April 22, 2014 Author Posted April 22, 2014 It's moving mechanicaly just ain't dumping Im not a baileys fan tbhCheers Quote
Vturbo Posted April 22, 2014 Posted April 22, 2014 Maybe you need a Bov with a softer spring perhaps Quote
PWG123 Posted April 22, 2014 Author Posted April 22, 2014 It worked perfectly before tho?Cheers Quote
PWG123 Posted April 23, 2014 Author Posted April 23, 2014 Erm it's on .8 I can't remember what it was on when I got itCheers Quote
