burgess18 Posted April 23, 2014 Share Posted April 23, 2014 Looking to go 300bhp with td04 hybrid whats best injectors to use that wont be under to much strain, ive been told 550cc are to big? Any ideasRegards Albert Quote Link to post Share on other sites
AdamB Posted April 23, 2014 Share Posted April 23, 2014 What management are you going to be using is probably the most important factor. 550's will be fine and will keep the fuel pressure fairly low. You'll ideally need a minimum injector size of 466cc/min to get 300bhp safely with a max duty cycle of 90%, you could go higher on the duty cycle upto like 95% but that's down to how comfortable your tuner is with running that sort of figure. Quote Link to post Share on other sites
Turk Posted April 24, 2014 Share Posted April 24, 2014 (edited) I think 550 are cool. I saw a set of 550s from a 3sgte going for £10 on ebay.Heres the item number 201073924382Just to be sure check up if they are 550 cc Edited April 24, 2014 by Turk Quote Link to post Share on other sites
