sk8chris Posted November 28, 2007 Posted November 28, 2007 hey guys just got a new kenwood headunit and im having a bit of touble taking out the tape player that came in the car its a sony one so im guessin it isnt standard, anyone here have any tips for getting the tape player out, any helps much appreciatd .thanks Quote
RobSR Posted November 28, 2007 Posted November 28, 2007 take off the dash facia which is around the original headunit. There are two screws on the beam below the heater controls. Once you have done that gently prise the bottom of the facia away from the dash (it is clipped on), once you have done this you will have a clear view of the headunit and the surrounding area. The is another 4 screws that you will then need to remove. The hold the metal bracket onto the dash, which also holds the headunit in place. There is two screws above, and two screws below, that are a little harder to acces. Once you have done that the whole head unit and bracket will come out, discounect all the wires, and then your free. I think the head unit is screwed into the bracket so there will be a few more screws. Simply undo these, and the headunit will come out of the bracket. simply re-install the new headunit, using the pointers you used to take it out Hope this helps. Thats all i can remeber when i helped do it.......Rob Quote
sk8chris Posted November 29, 2007 Author Posted November 29, 2007 cant seem to find any screws around the tape player,anyone have any other ideas how to get it out? its an ep82 if that makes a difference about how the headunit can be removed.thanks Quote
RobSR Posted November 29, 2007 Posted November 29, 2007 ahhhhh sorry mate i did it on a ep91 thats why Sorry i cant really help you regarding fitting it into an '82 Rob Quote
sk8chris Posted November 29, 2007 Author Posted November 29, 2007 its alright mate thanks for trying anyway. Quote
sk8chris Posted November 30, 2007 Author Posted November 30, 2007 just got intouch with the garage where i bought the car to ask about removing the headunit and they said its rear mounted and they wanted £40 to remove it, i took the panel off under the steering wheel but i cant see anyway off getting to it, so anyone have any ideas on how to get it out? also does a 1995 ep82 have wires runnig to the back for rear speakers?thanks Quote
jon5698 Posted November 30, 2007 Posted November 30, 2007 Right mate what you want to do is pull off the 2 nobs for the heater controls, then there is 2 small slots either side of the heater control unit, put a small screwdriver in these and pull the unit out. Then disconnect the heater controls, remove the 3 screws that you can see, pull off the dash fascia and disconnect your hi/lo button, hazard warning and rear heated screen buttons. Remove the 4 screws holding the radio in, swap the old one for the new one and you are done. Quote
sk8chris Posted December 1, 2007 Author Posted December 1, 2007 thanks alot got the headunit it now Quote
