Not sure how hard they're to change but I have a breaker here that Im willing to chop up if you need the slam panel
Aamir
The upper part is welded I believe. The middle section is bolted to the headlight brackets, just unbolt it from there and away you go, you have to remove the indicators to get to it though.
As above quite a few spot welds to drill on the slam panel but take your time plus a bit of common sense not hard to do.
Good luck with it.
