Adam-Gt- Posted May 4, 2014 Posted May 4, 2014 Any removed the rubber around the rear windown before ??Isit glued in I don't want to take out the window just the rubber as there is some rust that needs grinding out Quote
Adam-Gt- Posted May 9, 2014 Author Posted May 9, 2014 I forgot I posted this my bad !! It's an 82 buddy Quote
rinseep82 Posted May 9, 2014 Posted May 9, 2014 It will have a bit of adhesive on it but that's all unscrew the wi do from the inside where the seatbelts are you'll need a long 10mm socket and take the window out the just give it a good tug it will all come out as one piece Quote
Adam-Gt- Posted May 9, 2014 Author Posted May 9, 2014 I'm on about the boot window buddy I've already removed the rear side windows Quote
rinseep82 Posted May 9, 2014 Posted May 9, 2014 Ahhh sorry mate it's bonded innit?? Think it will have to be cut out Quote
Adam-Gt- Posted May 9, 2014 Author Posted May 9, 2014 Yea I think it is I've had a look just want the rubber out to sort out some surface rust on the boot I'll get the Stanley on it 2mos Cheers for the responses tho buddy Quote
